Civil 3D Forum
Manually rotate point lables?
2 REPLIES 2
Topher5000
212 Views, 2 Replies
I'm doing a pavement elevation plan & need to rotate the elevation text manually.   For instance, on one side of the road I need the text at 45d & the other at 235d, and at intersections I'll need to rotate the text to varying angles.  Is this possible?
2 REPLIES 2
Jeff_M
in reply to: Topher5000
Yes, you can rotate CogoPoint labels in a variety of ways.
1. via grips:
2. Use QuickProperties (will need to adjust the QP settings to show the Label Rotation):
3. Use the Properties Pallette (can set more than one with this method):
4. Use the Point Editor Panorama (can set more than one with this method):
Jeff_M, also a frequent Swamper
Topher5000
in reply to: Jeff_M
Thanks.  I need to pay better attention I guess.
Rail Community
