I'm doing a pavement elevation plan & need to rotate the elevation text manually. For instance, on one side of the road I need the text at 45d & the other at 235d, and at intersections I'll need to rotate the text to varying angles. Is this possible?
Solved by Jeff_M. Go to Solution.
Yes, you can rotate CogoPoint labels in a variety of ways.
1. via grips:
2. Use QuickProperties (will need to adjust the QP settings to show the Label Rotation):
3. Use the Properties Pallette (can set more than one with this method):
4. Use the Point Editor Panorama (can set more than one with this method):
