i'm revisiting an old project. at the time, i couldn't figure out an issue and had a time constraint so i manually edited linework on one section by ctrl+clicking on the lines and moving them. but now i need to redo some work with a new profile and the section i edited manually wont respond to anything i can come up with. i even deleted it and resampled, but it came right back the same way. anyone know how to get it to become editable again?
Solved by rgalbraith. Go to Solution.
Delete the Corridor Station from the Region overrides in the Corridor Properties.
I use Civil 3d for many years and i didn,t know that i can edit section with this way.
Thank you
