I changed the default parent point lable and point styles and there are no child overrides but when I manually insert points they don't use the default styles. How do I get manually created points to use the default settings? I made the change on the Point "Edit Features Settings" and those settings are also the same in the command settings and the override check boxes are unchecked.
Is there a fix for this issue (user error or software issue)?
Solved by JOHNHAAG6922. Go to Solution.
Solved by sjg. Go to Solution.
That worked! Thank you - have a great weekend!
I'm trying to figure out the same thing. What did you do to the all points group? I can change the styles & see it update in my point but I'm looking for something in the all point group that says "use default style" so that when I change it in the command settings, I can just create points manually using the default settings.
