Civil 3D Forum
Manual pt's not using new lable an d point style default settings
3 REPLIES 3
JOHNHAAG6922
455 Views, 3 Replies
I changed the default parent point lable and point styles and there are no child overrides but when I manually insert points they don't use the default styles.  How do I get manually created points to use the default settings?  I made the change on the Point "Edit Features Settings" and those settings are also the same in the command settings and the override check boxes are unchecked.
Is there a fix for this issue (user error or software issue)?
John J. Haag, P.E.
Haag Engineering Consultants, Inc.
3 REPLIES 3
sjg
in reply to: JOHNHAAG6922
Check your _All Points, point group. That iis where the labels are coming from.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
JOHNHAAG6922
in reply to: sjg
That worked!  Thank you - have a great weekend!
John J. Haag, P.E.
DRW_CAD
I'm trying to figure out the same thing. What did you do to the all points group? I can change the styles & see it update in my point but I'm looking for something in the all point group that says "use default style" so that when I change it in the command settings, I can just create points manually using the default settings.
Rail Community
