Jon-Boy wrote:
> Jason, when you say edit them in the survey data base does this mean
> that if i need to alter the level of all my points by 0.245m then i
> will have to go through all of my target heights one by one and work
> out what the new level will be manually and then input it into the
> appropriate box???? could you please tell me what the edit datum
> command is for then? and how is it possible to align survey points in
> the drawing?
> I dont mean to sound rude or facetious, just getting very frustrated
> with what is supposed to be; Qoute from the Autodesk website:
> "Autodesk Civil 3D streamlines your field-to-office processes using
> survey communication, data transfer, analysis, reduction, and
> automated drafting. Now Civil 3D has you covered, from initial survey
> through to final plans."
> hmmmmmm....................... no comment
I'll join you in your "no comment" - I like things to be easier rather
than harder. However, all isn't quite lost...this extension should be
on the Civil Engineering Community Site -
http://www.civil3d.com/index.php/2007/02/new-survey-extension-available-for-civil-3d/#more-584
A quote from that article:
The purpose of this command is to perform a simple translation of a
selected survey network, given a base point, rotation angle, a
destination point, and a change in elevation (optional).
Looks like what you wanted - edit datum as well as rotation. I'll be
away from an internet connection for most of today (and tonight) but if
you can't find it, let me know and I'll try to see if I can find it to
email to you - I think I'm using the third or fourth revision of the
extension.
Jason Hickey
Civil 3D 2007, SP3
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
www.civil3d.com
