Civil 3D Forum
Manhole Sump
2 REPLIES 2
1689 Views, 2 Replies
Manhole Sump
Hello All:  Anyway to set the default "sump" value from 2 to 0 for manhole.  I'm using the default sanitary manhole style in civil 3d and it has a 2 foot sump in it...?   I'm not sure I want a 2 foot sump in my sanitary manholes...  thanks for the help  in advance...
Also, is there a way to set invert matching as a default rather than having to change every structure.
Lastly,  How do we set a default slope for pipes ?
thanks a bunch again...
2 REPLIES 2
wfberry
For Sumps
Toolspace -> Settings -> Structure -> Structure Rule Set -> (pick the style) Rt click ->  Go to the Add Rule (if not available) to set sump to "0".
Bill
If I remember correctly this will not change to ones you already have set.
ccoles
in reply to: wfberry
But, there is a command under Pipe Networks Modify to 'apply rules' to structures already set. This would reset the sump to zero if the rules are set that way.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Rail Community
