I am labeling my manhole from the bottom with name,station, rim, invert. Between the name and station there is a line going up to the bottom of the manhole. On some of the lines do not get the manhole, on some the line it goes into the manhole. How do I set it for the line to stop and the bottom of all manholes?
Prospector, settings tab, right click Pipe Network, Edit Feature Settings, Default profile label placement, See image. I think this is what you are looking for.
You probably wouldn't see any changes for existing labesl. Relabel the mnaholes and see if that helps.
