Civil 3D Forum
Manage Attributes
2 REPLIES 2
bf
227 Views, 2 Replies
Manage Attributes
2014.  In help, it says to "Click Insert tab-Block Definition panel-Manage Attributes"  In my display, when clicking the Insert tab, I only have a "Block" panel, not a "Block Definition" panel.  Trying to get to the Sync command.  Any help?
2 REPLIES 2
rendarin
in reply to: bf
Try switching from the Civil3D ribbon set to 2D Drafting and Annotation.
Willy_Campbell
in reply to: bf
You can also change your workspace over to Planning and Analysis [MAP tools], under the Insert tab, you will find the Manage and Syncronize tools under the AutoCAD Attributes Panel [next to the Block Panel]. This holds true for all previous versions as well.
It appears that the HELP file listed was written specifically for where to find these tools in MAP 3D, and MAP workspace.
The shortcut for these are:
Manage Attributes = BATTMAN
Syncronize = ATTSYNC
Willy Campbell
Rail Community
