AutoCAD Civil 3D General Discussion
jigglehips
Message 1 of 1 (42 Views)
making the Grade
42 Views, 0 Replies
01-28-2005 03:19 AM
RE: Civil 3D 2005 Grading
I'm trying to create a simple cell design, just a hole in the ground with 1:3 side slopes. Then from around it's crest line project up to the restoration levels above. It seems to have problems using a 3D polyline to project up (I get an error message), LDT has no problem with exactly the same lines. If I break the 3D polyline into small simple sections it seems to cope better and actually creates a grading object. However, I then end up with multiple grading objects that aren't related to each other. When I explode them to trim the contour lines off, I can't because it says they aren't in the current UCS (it gives it an incorrect 'Z' value).
With regard to the trimming, I can't do it in AutoCAD 2004 now as well.
Any help would be fantastic as I've spent the last week bouncing from one problems to another.
Post to the Community
New Post
Need installation help?
