Hey,
I am trying to stick with one program(Autocad) and not use Softree, but when someone graphically represents something in Softree it looks way more professional than the profiles and cross sections I am creating in autocad. Is there any way to make these graphs look more professional other than tweaking in Edit View Style? Thanks
Solved by troma. Go to Solution.
Solved by w_davis. Go to Solution.
I guess the main thing that I think looks "professional" are dots for the minor grid lines but im not sure if that is possible in autocad c3d 2010
I figured it out, make the minor vertical interval smaller and then under display change the horizontal grid linetype to dots and adjust the scale till it works. This in my opinion looks alot better. All was done under edit Profile View Style.
