Civil 3D Forum
Making graphs(profiles and cross sections) look professional?
4 REPLIES 4
w_davis
411 Views, 4 Replies
Hey,
I am trying to stick with one program(Autocad) and not use Softree, but when someone graphically represents something in Softree it looks way more professional than the profiles and cross sections I am creating in autocad.  Is there any way to make these graphs look more professional other than tweaking in Edit View Style?  Thanks
4 REPLIES 4
Jeff_M
in reply to: w_davis
An example of what you think 'professional' should look like would help. Yes, you need to edit the ProfileView and SectionView styles to suit your desired output.
w_davis
in reply to: Jeff_M
I guess the main thing that I think looks "professional" are dots for the minor grid lines but im not sure if that is possible in autocad c3d 2010
w_davis
I figured it out, make the minor vertical interval smaller and then under display change the horizontal grid linetype to dots and adjust the scale till it works.  This in my opinion looks alot better.  All was done under edit Profile View Style.
troma
Like this?
Mark Green
Working on Civil 3D in Canada
Rail Community
