I am having difficulty getting the tie down portion of the assmebly to work. The project includes adding a 5' wide paved shoulder and a 5' stabilized shoulder. I have constructed the assembly but the daylight portion of the assembly will not show in the section view.
See picture below.
Solved by AlmasSuljevic. Go to Solution.
Do you see the daylights in the Section Editor? Will it help if you re-sample?
