Civil 3D Forum
making a block (from exploded surface) un-selectable
3 REPLIES 3
autoMick
227 Views, 3 Replies
OK folks....
I've got a surface that I want to be semi-tranparent, it seems the only practical solution at the moment is to eXplode it so that layer transparency will affect it. Which is fine, I guess, for the time being (well actually it's not but we don't have much choice with 2013 do we?).
Putting that aside, my issue now is that every time I hover over the exploded block, it does a selection 'preview' which is distracting to say the least. So I want this exploded surface to be unselectable. Is there a way? If I lock the layer, it dims it, which I don't want. If I freeze the layer the exploded surface just disappears. Surely there's a simple solution ??
- Mick
Civil3d user in Australia since 2012.
3 REPLIES 3
Jeff_M
in reply to: autoMick
You can extract the Elevations from the surface rather than exploding the surface, then select the resulting solids to group them into a block if you want.
Turn off selection preview:
autoMick
in reply to: Jeff_M
Thanks Jeff - I'm embarrassed that I didn't find that myself. Exactly what I was after!
- Mick
Jeff_M
Sure thing...see my edited post above
Rail Community
