i will desidn track inline skate but i confused, use a corridor for build design track because this track have a different elevation.
wherher have solution or trick for design this track??
thanks
Solved by tcorey. Go to Solution.
I would consider making a profile for the inside line of the lane and then another for the outside. Use this outside profile to control the slope of the sections by attaching it as an elevation control in the Targets section of the corridor parameters. That should put you on the right track. 🙂
Best regards,
Tim
