What we've found is that if you "move" a project with DataShortcuts is that you need to make sure the old path can no longer be resolved (i.e. rename the original folder). There is DS information stored in the dwg file that holds information to the original file location, so if the old location can still be found, it will use that instead of what is in the DS XML files.
