If I change the size of, say, the "file open" box, and shut it down, then open it again, it goes back to the default small size. Is there a setting that I can change so that the dialog box size stay's to my selected size?
The dialog box will go back to the small default size no matter if I do or don't open a file. It's like that with all "file" dialog boxes, ei; the insert file dialog, xref dialog box, insert raster image dialog box, etc...
thsi is something i have always wanted myself. jeff, i tried your suggestion, and it does not seem to work for me. even after i open a file, the next time, the window size switches to the previous one.
Sort of an update. I also have Autocad 2009 installed and it's having the same issue. Do you think it might be a problem with one of the Windows components, ei: Microsoft .Net frameworks? I'm doing a WIndows update now. I'll keep you guys posted on the results.
Well after some research on this I cannot figure out why I CAN get mine (Open, Save, SaveAs, Select Xref, etc.) to stay resized. From everything I've read, this is a big wish for many programs...not just AutoCAD. Yet mine behaves just like those wishes are wishing for.
Win7 Ultimate x64
Graphic "Eye Candy" all on.
I have Admin privileges
Works in both C3D2010 & C3D 2011
I guess I should just be glad that it works here. 🙂
I find values in the Registry [ HKEY_USERS\S-1-5-21-2108289806-3803732536-250371831-1001\Software\Autodesk\AutoCAD\R17.2\ACAD-7018:409\<profile>\Dialogs\Open Drawing ]. Just do a search for Open Drawing.
As far a I remember these control the size of the Dialog. It's been years since I changed any of them so I can't give further advice.
Allen
Allen Jessup
CAD Manager - Designer
It looks like those values are also saved in the <Profile>.arg file and could be edited there.
Allen
Allen Jessup
Are you running dual monitors? There is an issue with having the dialog boxes opening up on the non-primary screen.
Glenn your a genius. That was it. I do have 2 monitor's. I had the open dialog box on my secondary monitor. Once I had moved it to the primary monitor and adjusted the size, then I opened a drawing so that the new dialog size would save. The next time I opened a drawing, the dialog box stayed the new larger size. Thank you very much for everyone's input.
...so, is there a fix? Why shouldn't it work on either screen?
As far as I know there isn't a fix. Here is the tread from the AUGI forums where this was first brought up (http://forums.augi.com/showthread.php?t=97899). Sounded like Autodesk didn't know it was an issue.
There's another issue that's sort of annoying, too... It doesn't seem to remember the size of columns, if you resize them.
For example, I like to use STARTUP = 1, and I can resize the Startup dialog, but the "File" column always collapses back to its default width, and only really short filenames can be read in the column. I'm constantly expanding the column so I can see the full filename, but it's always collapsed again the next time.
The Startup dialog also doesn't display the drawings in any apparent order, can't be sorted, and displays the annoying .DST files in the list, but those are other issues...
The column size thing - could that be a Win & issue?
Do you mean a Win 7 issue?
No, that problem has been there for years now.
If you are running dual monitors and AutoCAD is running in the "Non-Primary" monitor, it seems like it will not maintain the last Dialog box size. Try moving the Autocad Application to the "primary" monitor.
If you just drag the dialog box to the primary monitor, it will remember size. Autocad application does not have to be on primary monitor
There is a fix. Just move the Open File Dialog Box to the primary screen. The AutoCAD window can stay on the secondary screen. As soon as the dialog box is moved (and used) to the secondary screen it won't maintain the last size.
You can also just drag part of the dialog box onto the primary screen. I resized mine so that it just barely crosses onto the main monitor and it will hold that position, just tricky to get it so that you can still see everything, and if you move it to see something you have to move it back before you hit open. But once you get it in a good spot it will stay. Hope they fix this one day having more than one monitor is becoming a standard for some people.
Regarding column width, someone on AUGI had this solution, and it works all across windows. I wish I could remember who it was, because it has saved my sanity from one of those sloppy Windows annoyances that lengthen our days.
In the dialog you want to adjust, right click on the column headings, then click "More". At the bottom of the dialog, type in a value for each column you want to adjust. You might have to tinker with it based on your screen settings, fonts, etc. but it works.I haven't found a Window program it doesn't work for.
