Is it possible to write a macro or something that I could run on a file that had many survey point (cogo) and explode the points?
My problem is my survey file with the existing surface is very large and sing is for a xref for background (cad) information is a resource hog. I want to explode all the data to simple cad graphics. However when I wblock or explode all the information, some of the blocks associated with points do not work. It is old as I can explode the same block and 2 time it will look correct and another it will be a odd scale or something. If I don't each point by point, all the blocks look correct.
Anyone have a good workflow for making a base file with just cad?
Thanks.
you never heard this from me, because stuff like this is frowned on, but in situations where I explode a lot of points I will use the isolate objects tools. I isolate all of the points and explode them twice & the unisolate. Works pretty good. Let me know if you have never youed object isolation. It is different than layer isolation.
I use this lisp to deal with the *U blocks. It explodes as many times as necessary, but will only explode *U blocks. It won't explode the resultant blocks or mtext from exploded *U blocks.
;;;Purpose: to explode blocks with names starting with *U. ;;;Looped until all are exploded. (defun c:XU (/ ss old-echo item ss1 item1) (setq old-echo (getvar "CMDECHO")) (setvar "CMDECHO" 0) (if (setq ss (ssget '((2 . "`*U*")))) (foreach item (mapcar 'cadr (ssnamex ss)) (command "Explode" item) (while (setq ss1 (ssget "_P" '((2 . "`*U*")))) (foreach item1 (mapcar 'cadr (ssnamex ss1)) (command "Explode" item1) ) ) ) ) (setq ss nil) (setq ss1 nil) (setvar "CMDECHO" old-echo) (princ) )
Mark Green
Working on Civil 3D in Canada
Any chance you'd be intrested in adding a burst command to this so it retains the sym layer if it's not hard coded in the style?
I need to explode points, then burst the undefined blocks and then xplode the undefined until mtext arrives.
Sure wish the export civil drawing worked on this...
John Mayo
