Do anyone have a lsp that changes the object layers in the drawing settings tab? I have a couple layers that depending on the file I am in I wish to change the layers. I browsed a couple google searches but maybe couldn't understand what I was reading. Thanks.
Just make a couple "dummy" blank dwt's which have the Object Layers set as needed for each scenario.
How this works is when the "Current.dwg" open needs the object layers set differently do the following:
1. Open "Dummy" Layers.dwt & set Toolspace to "Master View".
2. Make Current.dwg the active drawing Window.
3. On Settings Tab of Toolspace > Rt. CLick on drawing name Layers.dwt > Edit Drawing Settings > select Object Layers tab > OK.
4. On Settings Tab of Toolspace > Rt. CLick on drawing name Current.dwg > Edit Drawing Settings > select Object Layers tab > Notice the Object Layers are automatically populated by those from the Layers.dwt.
We do this all the time for various Pipe Network types which have different Object Layers. the various PN Object Layer dwt's are on the network.
