Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
lowering 3d polyline
8 REPLIES 8
Message 1 of 9
raptorsi
2553 Views, 8 Replies
I have a problem. I have a 3d polyline with points with heights. I want to lower it for 10cm. One way is manualy, but there is too much points. Is there easyer way to do it? Now i have heights of the top of the pipe, now i need heights of bottom of pipe (-10cm). Help
Regards
8 REPLIES 8
Message 2 of 9
Pointdump
in reply to: raptorsi
R,
If you convert the 3D Polyline into a Feature Line, you can Raise or Lower the entire line Incrementally:
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 9
raptorsi
in reply to: Pointdump
Thank you very much Smiley Very Happy
Message 4 of 9
Jay_B
To add to Dave's suggestion, a 3D Polyline can also be Raised / Lowered using the RaiseLowerFeatures command.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 5 of 9
Pointdump
in reply to: Jay_B
Jay,
I didn't know about RAISELOWERFEATURES. I just tried it and it works great! Thanks.
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 9
antoniovinci
Apologizing for my ignorance, but... what about simply applying the _MOVE command to the 3Dpoly, from 0,0,0 to 0,0,-0.1 ..?
Message 7 of 9
neilyj666
That's far too old school.....;)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 8 of 9
Pointdump
in reply to: antoniovinci
AV,
"Apologizing for my ignorance..."
We'll let it slide this time Antonio, but needless complication is how we do things these days. You need to move on from the 1990's.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 9
MikeEvansUK
That's just what I do and guess what. It (the move command) also works for Pipes, featurelines and profiles too.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Rail Community
Ā
Ā
