I have a problem. I have a 3d polyline with points with heights. I want to lower it for 10cm. One way is manualy, but there is too much points. Is there easyer way to do it? Now i have heights of the top of the pipe, now i need heights of bottom of pipe (-10cm). Help
Regards
Solved by Jay_B. Go to Solution.
Solved by Pointdump. Go to Solution.
R,
If you convert the 3D Polyline into a Feature Line, you can Raise or Lower the entire line Incrementally:
Dave
Dave Stoll
Las Vegas, Nevada
To add to Dave's suggestion, a 3D Polyline can also be Raised / Lowered using the RaiseLowerFeatures command.
Jay,
I didn't know about RAISELOWERFEATURES. I just tried it and it works great! Thanks.
Dave
Dave Stoll
Las Vegas, Nevada
Apologizing for my ignorance, but... what about simply applying the _MOVE command to the 3Dpoly, from 0,0,0 to 0,0,-0.1 ..?
AV,
"Apologizing for my ignorance..."
We'll let it slide this time Antonio, but needless complication is how we do things these days. You need to move on from the 1990's.
Dave
Dave Stoll
Las Vegas, Nevada
