Civil 3D Forum
Low Quality PDF
4 REPLIES 4
kolk
247 Views, 4 Replies
Low Quality PDF
I am having an issue creating pdf's from Civil 13.  Specifically, we typically use the Sheet Set Manager (SSM) to create our plans, but the patch plotting to pdf did not work (I think this is typical).  At the advice of another office we purchased AcroPlot.  We can now create a pdf plan set from the SSM, but it's not consistent...some sheets are fine, while others are blurry, and some just have a strange look to them.
Any thoughts on this from ACAD Land?
Thanks in adavnce!
4 REPLIES 4
Jay_B
in reply to: kolk
We have good luck here using the built in DWG To PDF.pc3
Having said that, there are several settings within the pc3 which impact output quality if not properly set.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
neilyj666
in reply to: Jay_B
The supplied dwg to pdf.pc3 can't do hatch transparency very well at all
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
kolk
in reply to: neilyj666
That's where we seem to running into trouble (areas with hatching), but again, it's not consistently that way
neilyj666
in reply to: kolk
I use Bullzip PDF printer to print transparent hatches to pdf - not perfect but the best workaround I've found
Rail Community
