Civil 3D Forum
Low Point Label
13 REPLIES 13
Message 1 of 14
EddyL
2415 Views, 13 Replies
Low Point Label
 Is there a way to label the low point of a profile or alignment that doesn't have any vertical curves? We have an existing alignment and profile which is reatively flat, and we'de like to establish and label the low points for drainage improvements.
13 REPLIES 13
Message 2 of 14
jmayo-EE
in reply to: EddyL
We use a Profile Station/Elevation label. It is not automatic or dynamic but it will read the elevation correctly when moved around the profile view.
John Mayo
Message 3 of 14
EddyL
in reply to: EddyL
 Are you refering to a profile view labels or profile label styles?
Message 4 of 14
jmayo-EE
in reply to: EddyL
Sorry Eddie. I was talking about a profile view label.
John Mayo
Message 5 of 14
EddyL
in reply to: jmayo-EE
So you are manually picking the point? Being that it's so flat and irregular, we were hoping there was a way to automatically locate and label the low point.
Thanks.
Message 6 of 14
jmayo-EE
in reply to: EddyL
Yes, I manually pick the point and have the same wish for an automatic label...
John Mayo
Message 7 of 14
Joe-Bouza
in reply to: EddyL
I dont see it on the profile but you can add ProfileGeometry points to alignment lables to highlight the LP, HP and so on i plan.
Your Name
Message 8 of 14
BrianHailey
in reply to: EddyL
You would need to use a grade break label. You could create an expression to determine if the grade in is negative and the grade out is positive. If that's true, the grade break is a low point. You could also use the same concept to determine if it's a sag regardless if there is a low point. That expression would just make sure the incoming grade is less then the outgoing grade.
http://screencast.com/t/cEh6ObmdU
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 9 of 14
BrianHailey
in reply to: Joe-Bouza
By chance did you try this without a curve? I wasn't able to get it to work.
http://screencast.com/t/9PyDX46Ty0bv
GEI Consultants
My Civil 3D Blog
Message 10 of 14
jmayo-EE
in reply to: EddyL
Hey Brian, will that label only the lowest low point and the highest high point or will it label all grade breaks?
John Mayo
Message 11 of 14
Joe-Bouza
in reply to: BrianHailey
Yes I do all the time. I'm surprised - you used the codeset style and added the elvation parameter?
Your Name
Message 12 of 14
BrianHailey
in reply to: EddyL
But that will label all of the grade breaks and not just the low points. It sounded like the OP wanted just the low points and not the grade breaks that didn't result in a low point "for the drainage plans".
GEI Consultants
My Civil 3D Blog
Message 13 of 14
Joe-Bouza
Then he could add the conditional statements like you refered to in your earlier post, no?
Your Name
Message 14 of 14
Grimes_MG
Check out this thread on HP/LPs that only show when they are HP/LP and not GBs.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Adding-minimum-and-maximum-points-in-profile-...
Win7 (x64), EVGA 790i, 8GB RAM, EVGA 8800GT, 250 GB iSSHDD, & RAID 0/1
Rail Community
