parcels are labeled dynamically, but they are not dynamic in the sense that profiles are dynamic to a surface. The post above has it right when he says that the other parcel lines will not update automatically.
In order to make a block of parcels, you only need the back lot line and a line at either end of the alignment which goes back to the back lot line. Once this parcel is created, you further divide it by placing new lines to divide it using the parcel create by layout.
if you try to create all your parcels with closed polylines, your in for exactly what your seeing. Alot of unwanted problems.
Get the book mastering Civl3D, I'm sure it gives best practices for dealing with parcels in a manor that is easy to understand.
good luck,
Dan
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
