Does anyone knows how to enable the Civil 3D right clikc menu?. For some reason I lost it and it does not give me options for Civil 3d Objects only regular AutoCAD options.
Solved by Hidden_Brain. Go to Solution.
Are you using 2 monitors? Sometimes if you use just one, the pop-ups & dialogs may get lost. There's a way to get them to show up where the cursor is, but I don't remember it. Hope some wone else will chime in.
Reid
have you tried looking under OPTIONS>USER PREFERENCES>RIGHT CLICK CUSTOMIZATION?
i just revisited this thread to mention the PICKFIRST, but you have solved it already.
Using AutoCAD Civil 3D 2015 and the right-click shortcut menu will not appear.... Checked the pick first pick add variables and also went to options > user preferences > right click customization .... and checked the appropriate boxes were checked. No clue why it won't work. Right click will work for other commands, for example when selecting quick click to repeat command option it will do this, however it just won't display the shortcut menu. Very frustrated havent found a forum with the answer yet
I thought I was at the time and it really doesn't matter solved the problem, had to do with the workspace. I dont know how it got altered, just glad its resolved
@Anonymous wrote:Figured it out....Pickfirst variable got reset to 0. Just changed back to 1 and I'm go to go now.
PICKFIRST set to 1 and it works perfectly...
Thanks...
