AutoCAD Civil 3D General Discussion
Valued Contributor
0 Kudos
Post 1 of 8
Lost Right-click in Assembly Properties
205 Views, 7 Replies
11-08-2005 09:50 AM
I am trying to rearrange my assembly groups so that a markpoint is above the linktomarkedpoint. However, when I open the Assembly properties and right-click on a group, no menu appears! I've tried entering the box from both the assembly object and the Prospector tree, and I've tried closing out, even restarting the computer, with no effect.
I'm running C3D 2006 with SP2; all my right-click customizations are set to shortcut menu without a time delay. My mouse is a microsoft mouse running on the plug and play driver, and all other right-click menus seem to work correctly. Any ideas besides a full reinstall?
*James Wedding
Post 2 of 8
Re: Lost Right-click in Assembly Properties
11-08-2005 10:51 AM in reply to: craigremillard
PICKFIRST?
James Wedding, P.E.
Technology Manager &
Associate
Jones & Boyd, Inc.
Dallas, TX
XP/2 on P4-3.4/1G
LDT 2006 & C3D2006/SP1
Valued Contributor
0 Kudos
Post 3 of 8
11-08-2005 04:00 PM in reply to: craigremillard
nope, didn't work
Distinguished Contributor
1 Kudo
Post 4 of 8
02-28-2006 09:28 AM in reply to: craigremillard
I am having the same problem, with the difference that all of my R-click commands do not appear, that is, when selecting an Alignment, Profile, Template or Corridor, my corresponding commands do not appear when I R-click them... I tried checking on Options- User Preferences tab - R-click Customization - and all options were checked to Shortcut, however, that's not working either..... Any suggestions?
*James Wedding
Post 5 of 8
02-28-2006 10:03 AM in reply to: craigremillard
Just guessing here... what is PICKFIRST set to?
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2006 SP2
XP Tablet, SP2, 2GHz, 1.5G
www.eng-eff.com
www.civil3d.com
1 Kudo
Post 6 of 8
02-28-2006 11:54 AM in reply to: craigremillard
That's right James.. .that was the solution.... I did not know about that command, which for some reason got set to 0. That fixed it... Thank you!
Active Contributor
1 Kudo
Post 7 of 8
08-06-2011 06:54 AM in reply to: craigremillard
Hey!
If you are working on two or more extended monitors, try right-click on Construction Tab tree structure elements on MAIN SYSTEM MONITOR (nr. 1) , before drag Assembly Properties window here (to  MAIN SYSTEM MONITOR, where windows start button is).    I had this problem too,  and find this solution.
*Expert Elite*
161 Kudos
Post 8 of 8
08-06-2011 11:50 AM in reply to: rutar
Hey rutar:
It is unlikely that he is waiting since it has been nearly 6 years since his post.
<G>
Bill
Post to the Community
New Post
