Civil 3D Forum
Lost Right-click in Assembly Properties
8 REPLIES 8
Message 1 of 9
452 Views, 8 Replies
I am trying to rearrange my assembly groups so that a markpoint is above the linktomarkedpoint. However, when I open the Assembly properties and right-click on a group, no menu appears! I've tried entering the box from both the assembly object and the Prospector tree, and I've tried closing out, even restarting the computer, with no effect.
I'm running C3D 2006 with SP2; all my right-click customizations are set to shortcut menu without a time delay. My mouse is a microsoft mouse running on the plug and play driver, and all other right-click menus seem to work correctly. Any ideas besides a full reinstall?
8 REPLIES 8
Message 2 of 9
PICKFIRST?
James Wedding, P.E.
Technology Manager &
Associate
Jones & Boyd, Inc.
Dallas, TX
XP/2 on P4-3.4/1G
LDT 2006 & C3D2006/SP1
Message 3 of 9
nope, didn't work
Message 4 of 9
alberto_go
I am having the same problem, with the difference that all of my R-click commands do not appear, that is, when selecting an Alignment, Profile, Template or Corridor, my corresponding commands do not appear when I R-click them... I tried checking on Options- User Preferences tab - R-click Customization - and all options were checked to Shortcut, however, that's not working either..... Any suggestions?
Message 5 of 9
Just guessing here... what is PICKFIRST set to?
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2006 SP2
XP Tablet, SP2, 2GHz, 1.5G
www.eng-eff.com
www.civil3d.com
Message 6 of 9
alberto_go
That's right James.. .that was the solution.... I did not know about that command, which for some reason got set to 0. That fixed it... Thank you!
Message 7 of 9
rutar
Hey!
If you are working on two or more extended monitors, try right-click on Construction Tab tree structure elements on MAIN SYSTEM MONITOR (nr. 1) , before drag Assembly Properties window here (to  MAIN SYSTEM MONITOR, where windows start button is).    I had this problem too,  and find this solution.
Message 8 of 9
wfberry
in reply to: rutar
Hey rutar:
It is unlikely that he is waiting since it has been nearly 6 years since his post.
<G>
Bill
Message 9 of 9
Colin.GaudetGBKQ4
in reply to: rutar
I would have never found this solution, thank you for suggesting this additional solve! 9 years later with COVID-19 and everyone working from home and laptops, this happens so much more frequently.
Here is where it got strange though, I have 3 monitors.
Laptop screen - The right-click works
DVI-D to HDMI connected monitor - The right-click works
HDMI to HDMI connected monitor - The right-click doesn't work (Tried with and without a USB-C hub)
For me it seems to be either monitor or connector dependent for secondary monitors.
Rail Community
