I needed to check some vehicle turning movements against my design, so I started Civil 3d from the AutoTurn icon. As I was working I noticed that I don't have any Tooltips anymore. I've checked the global tooltip settings in the Civil3d settings, and the Autocad options, and also the tooltip settings for individual objects. Everything is turned on but no joy.
I also found that the glyphs which should appear when snaps are turned on aren't visible, although the snaps do work properly. Once I had finished with the vehicle checks I shut down, and then restarted from the Civil3d icon but the behaviour hasn't changed back to normal. I've also tried repairing the installation - next step will be a full reinstall.
Suggestions anybody ??
Solved by rjairath. Go to Solution.
Steve, you prolly tried these but:
opening one of your other Profiles
opening one of your other Workspaces
Exporting the acad portion of the registry of a "working" installation and restore in yours (maybe not?)
Using a text editor that will compare two files of variable settings (your current vs. a "working" installation)
Good luck.
-Steve
Please go and check the following;
type 'op'
in the option tab select the 'Drafting' tab
make sure under autosnap setting
make sure there are check marks turned on for
Marker
Magnet
Display AutoSnap tooltip
Display AutoSnap aperature box
let me know if that works
And we have a WINNER !!!
I was sure that it would be something simple, but just couldn't find the right setting to check.
Thanks very much.
