Civil 3D Forum
Lossing my contours in Civil3D 2013
5 REPLIES 5
RalphBrown99
452 Views, 5 Replies
Hi:
I have build a surface definded by polylines but time to time I lose the contours generated by the surface. I lost them when I re-open the file after closing it the day before or in other commands like save. I am Windows 7 user, 64 bit so I am not sure if some one else have had this problem. Maybe I have to check my RAM perhaps?
Thanks in advance
Rafael
5 REPLIES 5
neilyj666
in reply to: RalphBrown99
Do you have Level of Detail switched on?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
RalphBrown99
in reply to: neilyj666
Hi:
Thanks for the answer. I do not what is level of detail so I am not sure if I have it turned on or off. However I think that it is not the problem due I lose contourse for one of the surfaces that I have in the screen. The other one that defines my dams are intact
Rafael
BrianHailey
Level of Detail can be found HERE.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
neilyj666
If you see this,
then it is switched on; if not, then post the dwg
RalphBrown99
Hi:
Thanks for the instruction. I am keeping my contours by now. I hope to follow up just in case I have this problem again. The lavel of detail commna is working by now.
Cheers
Rafael
Rail Community
