Distinguished Contributor
RafaelMoreno
Message 1 of 6 (326 Views)
Lossing my contours in Civil3D 2013
326 Views, 5 Replies
12-18-2012 01:51 PM
Hi:
I have build a surface definded by polylines but time to time I lose the contours generated by the surface. I lost them when I re-open the file after closing it the day before or in other commands like save. I am Windows 7 user, 64 bit so I am not sure if some one else have had this problem. Maybe I have to check my RAM perhaps?
Thanks in advance
Rafael
Do you have Level of Detail switched on?
neilyj
Message 2 of 6 (323 Views)
Re: Lossing my contours in Civil3D 2013
12-18-2012 01:52 PM in reply to: RafaelMoreno
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
RafaelMoreno
Message 3 of 6 (306 Views)
12-18-2012 02:47 PM in reply to: neilyj
Hi:
Thanks for the answer. I do not what is level of detail so I am not sure if I have it turned on or off. However I think that it is not the problem due I lose contourse for one of the surfaces that I have in the screen. The other one that defines my dams are intact
Rafael
BrianHailey
Message 4 of 6 (285 Views)
12-18-2012 08:54 PM in reply to: RafaelMoreno
Level of Detail can be found HERE.
Brian Hailey
CAD-1.com
My Blog
neilyj
Message 5 of 6 (278 Views)
12-19-2012 12:06 AM in reply to: RafaelMoreno
If you see this,
then it is switched on; if not, then post the dwg
neilyj
RafaelMoreno
Message 6 of 6 (258 Views)
12-19-2012 02:06 PM in reply to: RafaelMoreno
Hi:
Thanks for the instruction. I am keeping my contours by now. I hope to follow up just in case I have this problem again. The lavel of detail commna is working by now.
Cheers
Rafael
