I migrated from AC3D 2010 32-byte to AC3D 2012 64-byte recently. When I migrate my projects to 2012 and open the old 2010 drawings in 2012 I lose the surface lines out of my section sets. It doesn't seem to bother the profile views, only the section views.
Is there a way to work around this problem w/o having to regenerate the section views?
Thanks.
Solved by Matt_Haokip. Go to Solution.
Let me add that the lines show up if I open the drawings in 2010. I opened up the model space in 2012 and the lines appear. They only disappear in paperspace.
Hi Darrell,
Please refer to the following blog as you seem to have similar issue as described in the blog:
http://beingcivil.typepad.com/my_weblog/2010/06/my-section-views-have-moved.html
