Civil 3D Forum
Losing Connection to Network Drives
6 REPLIES 6
khamilton
244 Views, 6 Replies
When I launch Civil 3D I temporarily lose connection to my netwrok drives.  Generally this will last ~5 minutes where I cannot access any netwrok drives through windows or open any files through Civil 3D that are located on a network drive.  After that everything seems to go back to normal.
This problem started for me with C3D 2014 so we installed 2015 to see if that would take care of the problem,  but it did not.
If any one knows how to correct this problem or has any ideas or suggestions I would really appreciate it.
6 REPLIES 6
Jay_B
in reply to: khamilton
Does this happen when you first log on to your computer in the morning and launch C3d?
Or whenever every time C3d is launched throughout the day?
If the former, it's possible that your system has not had time to properly map network drives and C3d is being launched before network drive mapping takes place.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
khamilton
in reply to: Jay_B
It happens whenever I launch Civil3D throughout the day, for instance today I had been logged in for ~3 hours before launching c3d.
Jay_B
Is it possible the program set to "Run as Administrator" but your logged in as a User?
If so, if you log in as Administrator and launch, does the problem go away?
C3D 2018.1
C3D 2016 SP4
khamilton
in reply to: Jay_B
Where do I find if it is set to Run as Administrator?
Jay_B
Right click on desktop shortcut > Properties > Shortcut Tab > Advanced > is one place to verify.
C3D 2018.1
C3D 2016 SP4
khamilton
in reply to: Jay_B
Thanks, just found that myself.  No, it is not set to run as Adminstrator.
Rail Community
