I am running Civil 3D 2014 on Windows 8.1 Pro 64-bit. I have Location Services turned off in Windows. Every time I start C3D, it requests my location from Windows and I get a error notification. How do I stop C3D from requesting my location? While we are at it, how do I disable WSCommCntr4.exe?
Solved by troma. Go to Solution.
GEOLOCATEME command toggles on/off location tracking.
Mark Green
Working on Civil 3D in Canada
GEOLOCATEME only controls the function in the current drawing. Executing it when Location Services is turned off in Windows produces the message "Unable to determine your current location." It does not stop C3D from attempting to access Location Services every time you run it.
Well, It appears InfoCenter is probably the source of the location requests. But, it appears if I uninstall InfoCenter, I also loose Help. Is this correct?
Mark Green
Or I could just type "help" on the Command Line ... In the new AutoCAD way of doing things, you are supposed to reduce kepboard useage, keep your head up and eyes on the screen. Hence the Ribbion and the graphic Help interface. Oh, well ... as often as I use Help, it won't be that big a deal. Thanks for the tip on the program. Interesting Autodesk lets you customize so many other things in AutoCAD, but not this. I'll put it on the AUGI Wish List.
@Anonymous wrote:
... In the new AutoCAD way of doing things, you are supposed to reduce kepboard useage...
Don't listen to them! Keyboard all the way!
Mark Green
Mark Green
