I was wondering if anyone knows of a way to locate where text styles are located within a drawng. I am creating templates and some text styles are being carried from one template to another when I create them and I would like to delete certain text styles. I have looked around the drawing, but cannot seem to locate them. Any ideas?
Rick Jackson
Survey CAD Technician VI
ok.....so I tried both loading the lisp and its asking for VBA ? which I have no idea what that is and I tried clicking on the 3rd party link mentioned by Jeff_M, in the previous reply, but that was asking me to type on the command line "CivilStyleproperties" and it does not accept as a command.
That Help file is describing a command available in the Sincpac C3D add-on package (i.e 3rd party program) so unless you have downloaded, installed, and activated it you won't have that command available.
Mark Green
Working on Civil 3D in Canada
Assuming you are just talking about text styles and not label styles, they can be deleted using the "purge" command as long as they are not in use or referenced by another style, multi-leader, etc.
If you have styles that call them try deleting or editing those styles first. That can be a lengthy process though, which is probably why you asked...
I have tried searchig the drawing for some of the styles, but cannot seem to locate certain text styles and I know somewhere in my drawing they are being used because I cannot purge them. I just can't seem to find a few, but it looks like after this discussion group there is no real easy way to locate them within a drawing besides searching the entire drawing for them myself so I can delete them and then purge.
Try this.
While in the drawing, go to the Settings tab in your prospector.
Right-click on the drawing name, and choose "Edit Label Style Defaults"
Inside that dialog, expand the "Label" section.
On the "Text Style" line, is there a down arrow in the "Child Override" column?
If so, left click on it (that will place a red "x" on top of the arrow), then press Apply.
Now you have just cleared all style overrides from child styles and all label styles in the drawing are now set to the text style listed in the "Value" column.
Now see if you can purge any of the other styles...
I'm not saying this brute force method is the right way to go, but it will at least tell you if you have a wide variety of styles in use - within the C3D label styles.
I know this is old but you can use the add in app below and also the purge command can usually show you where a layer is being used.
This worked for me on most of the layers.
https://apps.autodesk.com/CIV3D/en/Detail/Index?id=8629213286347851577&ln=en&os=Win32_64
You will find that the inbuilt purge command has had a huge upgrade in 2021 and now has the ability to show where the text styles, and anything else, is being used.
For Autocad objects, you can also select the object straight from the purge dialogue.
To use this functionality -
Run the purge command
Click on the Find Non-Purgeable Items button at the top of the dialogue.
Click on the item you want to purge - the details panel will show how many times it is being used, what object is being used in, including limited on Civil 3d usage locations - e.g. a text style might show as beng used in AECC_PROFILE_VIEW_STYLE five times, but does not show which style.
To select Autocad objects using the style scroll down in the Details pane until you see an icon of a blue square with a magnifying glass and click that icon
See attached screen shots.
thank you for the responses......we are going to download the add-on that was suggested for now.....we are using 2108, so I will be looking forward to being able to use the 2021 version at some point in the near future.
The purge is great but it doesn't always work such as the attached screenshot I have no idea where it is referring to.
I agree. some of the aecc names via the purge dialogue are helpful but I have the same issue with some.
Like your screen capture I also have no idea what AECC_LABEL_COLLECTOR_STYLE is.
Anybody else know?
the fastest way we found for this is to use the DUMPSTYLESANDSETTINGS command, and locate the instances of the layer/style etc. in the text file. Everything listed is under the C3D style they are used in.
