I'm using AutoCad 2013 Civil 3D. I'm trying to import the attribute table from a GIS shapefile into AutoCAD. I tried it in Map but could not get it to work. I could not find and object file in creating a quirey. Is thier some online documents that could help me out. I'm new to AutoCAD so any simple help would be appreaciated.
You must first import the GIS data into a drawing, save the drawing, and then attache that drawing into your working drawing. Once attached, you can query in the data you need.
Here's a video I put together that explains how to do this:
http://enceptia.com/importing-gis-data-civil-3d/
Watch the whole video before you jump in.
This is just one method. You can also use this method if you choose: http://www.augi.com/library/gis-to-cad-in-civil-3d
Hope this helps,
Jason
Try here http://docs.autodesk.com/CIV3D/2013/ENU/filesMAPC3D/GUID-8503FBE6-B094-4E8B-847F-B6787B674200.htm
The online help for Civil 3d 2013 is here http://docs.autodesk.com/CIV3D/2013/ENU/
