I'm embarrased to ask but cant find it in help. What is the Work flow to get a map int civil3d?
Your Name
Your Name
More of Dave's way.
1. Assign a coordinate system
2. insert/import/data connect an object or shape file
3. Use GEOMAP command, if you are not logged on to A360 it will ask you to,
Your Name
Your Name
@Joe-Bouza wrote:
GEOMAP ask me if I want to use online maps but never presents me with a sign in dialog, and I get no map
This is getting riduclous. How can it work for some and not others? What in the name of Mike can I be doing wrong?
Just click yes to use the live maps, if you are already signed on to any Autodesk servers it may not ask you to sign in or if your browser is checked to remember sign in & password. I found out that if you use LL83 coordinate system if doesn't display the maps either, are you using a state plane CS?
Your Name
Your Name
Sign in, dont sign it, force it to sign in. I'm starting to think you and Dave are messin with my head, now 🙂
...LL83 doesn't work? ...Oh, more new info as we move along
this is what I use : is that ok?
Your Name
Your Name
Joe,
Try watching the attached video & see if that helps.
I grabbed some data from link provded by Allen and was able to get the Bing map to come in correctly here.
http://www.screencast.com/t/stPL92CrvN
Your Name
Your Name
Joe,
Have you tried it on a different computer?
Dave
Dave Stoll
Las Vegas, Nevada
Hi Dave
I check on that, too.
hope I can tranfer my cui easily, otherwise I have to get the geolocation ribbon again. Thanks for hanging in there with me. I konw its been pretty painful to watch
Your Name
Your Name
Joe,
OK, let's try something and see if we can isolate the problem. Here's a 2015 drawing, default Imperial Template, with one single point and coord system set to AZ State Plane. Open this drawing and then try to bring up Bing Maps. If you don't have the Geolocation Ribbon, then just command-line it like Murph does. Report back.
Dave
Dave Stoll
Las Vegas, Nevada
Your Name
Your Name
Your Name
Your Name
Your Name
Your Name
Joe,
That is weird. Does your boundary have COGO points or is it just lines? If you've got points, post a text file.
Dave
Dave Stoll
Las Vegas, Nevada
it is a GIS shp file. I may have been uttering 88 but I meant 83. don't think there actually is an 88
Your Name
Your Name
Joe,
I figured you meant 83.
I'll see what I can do with your file.
Dave
Dave Stoll
Las Vegas, Nevada
Joe,
I FDO'ed your shape file into 2015 and I was able to instantly bring up Bing Live Maps:
I don't know what's going on.
Dave
Dave Stoll
Las Vegas, Nevada
@Pointdump wrote:
Joe,
Dave
So did I, worked ok. I set the dwg coordinate system to HARN/NY.NY-LIF then data connected then Geomap.
intersesting.
Any particular reason you went to HARN?
Your Name
Your Name
