Listing the XYZ coordinates of points in a table,
I couldn’t figure out how the XYZ coordinates of the points laying in the horizontal curve can be listed in a table the same way we do in the AutoCAD (attached)
Thank you
Best
Jamal
Solved by neilyj666. Go to Solution.
You can generate a list of coordinates at intervals along an alignment from toolbox tab in the Prospector, but if you want a table within the drawing then you'll have to create cogo points along the alignment then a table from them.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
You can use the "Create Points - Alignments" to create points at geometry points (see attached) and then create a point table.
Thank you very much guys for the help,
What other alternative do I still have to list the XYY coordinates of the Cogo points in a table?
The dwg file is attached
As I previously suggested create a points table (Civil Points are not exposed to the Data Extraction tools)
Jamal,
Forgive my inability to understand, but what exactly are you trying to do? Do you want a Report or a Table in the drawing? When you say "XYZ", do you mean Northing, Easting, and Elevation; or do you mean XYZ as in ECEF (Earth-Centered Earth Fixed)?
Dave
Dave Stoll
Las Vegas, Nevada
Neilyj for the help. My issue is resolved (attached)
My thanks are extended to Dave.
Best
Jamal
