Just started to use 2013 and all my lisps that I use are not loading automatically.
They are all in the start up suit but refuse to load, I can open load panel and load them manually and they all work, but why wont they load automatically?
Cheers
Solved by rkmcswain. Go to Solution.
The startup suite is unreliable, at best....
Create (or append if it exists) an "Acaddoc.lsp" file (NOT Acad2013doc.lsp!), and put your load functions in there.
Put this file in the TOP path in your support file search path (preferably a new personal path, like C:\CADSTUFF).
Example:
;; Acaddoc.lsp (load "mylisp") (load "myotherlisp") (load "\\\\server\\share\\path\\my_lisp_with_a_path") (princ " Acaddoc.lsp loaded ") ; end of file.
