Civil 3D Forum
LISP for area in acres and segment bearings & distances
16 REPLIES 16
Message 1 of 17
1617 Views, 16 Replies
I'm looing for a LISP routine that spits out the area of a closed polyline in acres along with bearings & distances of the segments. I'd also like curve information if the polyline contains one. Anyone have one or a link to one they would like to share?
Fred Mitchell
G&A
16 REPLIES 16
Message 2 of 17
Have you tried the Parcel tool?
face=Arial size=2>
Thanks, Joe
Joseph D. Bouza, P.E. (one of 'THOSE' People)
Civil 3D 2008
Win XP
pro
v 2002, sp 2
hp workstation xw4600
Intel Core Duo CPU
E7200
@2.53 GHz
3 GB RAM
NIVDIA Quadro FX 1700
(512MB)
"All Contours are Lies! "-(
AJ)
The mantra of a former Flamer:
If you
are forced to eat an Elephant, don’t complain about it; Take one bite at a
time.
In
memory of the King of Work-arounds
"The only Constant is Change".
"The only thing worse than training your staff, and having them leave is
not training your staff, and having them stay." 😮
A reminder taken
from Graphics Solution Providers' Calendar
page
"An
Equal Opportunity Annoyer" (DK)
Message 3 of 17
A little. I also need something for when a boundary DOESN'T close.
Fred Mitchell
G&A
Message 4 of 17
Somewhere I have a lisp that I used from DCA's
first release thru Softdesk8 which was just too slick (for it's time). I
couldn't locate it quickly though, but if that link doesn't do it for you I'll
look a little harder....might involve finding a PC that will read from an old
5.25" floppy.....
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
A
close.
Fred Mitchell
G&A
Message 5 of 17
ralstogj
here is an old rountine I still use for area in m2 written by the guys in the credits maybe you could adjust it
;TIP889.LSP Quick Areas: AUTOAREA.LSP (C)1993, Levin Rodriguez Trujillo
;Altered by Stephen Bindon Aug 1999
(defun C:AA ( / N SS1 NUM EN )
;;LCA - COMMENT: The LAYER command has new options.
(command "_.layer" "set" "0" "")
(setq N 0)
(setq SS1 (SSADD))
(setq PT (getpoint "\nSelect internal point of Area:"))
(command "BPOLY" PT pause)
(setq SS1 (entlast))
(setvar "CMDECHO" 0)
(command "_.AREA" "E" SS1)
(setq AREASS (getvar "AREA"))
(command "_.ERASE" SS1 "")
(setq SS NIL)
(command "_.layer" "make" "Text-Area" "")
(command "_.text" "style" "txt35" "m" PT "90" (strcat (rtos AREASS) "m[2]"))
(command "_.redraw")
(setvar "CMDECHO" 1)
);end autoarea.lsp
Regards
Justin
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
Message 6 of 17
There's also the Mapcheck Analysis in 2009+ that
allows you to select the labels of a pline and it gives you the closure &
area information.
A
close.
Fred Mitchell
G&A
Message 7 of 17
I currently have a LISP for the acreage (area). Ideally, I would like one that has that information along with the line/curve information.
Fred Mitchell
G&A
Message 8 of 17
omc-usnr
This is a major problem with sites as far as I'm concerned. Again, it's engineers coding the software, not surveyors. I've yet to find a boundary that really closes to four decimal places in recoded plats, and or field survey, so to arbitrarilly close a boundary just to have a site to start with, feels wrong to me.
Reid
Anybody know why this board will sometimes bounce a duplicate post every so often?? Edited by: OMC-USNR on Jun 19, 2009 8:18 AM
Message 9 of 17
omc-usnr
Reid
Message 10 of 17
Just for the record, the Product Designer for Survey is a licensed
surveyor in NH. You may not like his design, but it's not because he's
an engineer or code jockey.
JW
Message 11 of 17
Sinc
So who's the "Product Designer" for the Engineering side? Is that left to a single person, for everything?
If not, why is one person expected to come up with the entire design for Survey, but not Engineering? Is that a reasonable expectation?
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
Sinc
Message 12 of 17
I'm inpressed! In the last few weeks have found out there is a Market
Readiness Manager-Civil Engineering, a Surveyor Product Designer and can't
remember the exact title but something like "emergency response team" for
hotfixes. Can QA/QC be close? Things are looking up!
"James Wedding"; "P.E." wrote in message
news:6205179@discussion.autodesk.com...
JW
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4172 (20090619) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Message 13 of 17
I'm also "impressed"! 🙂
http://www.eset.com
Message 14 of 17
stacy.dunn
Hey Fred,
Send me your contact information. I think I have exactly what you need.
stacy.dunn
@kimley-horn.com
Stacy Dunn
Message 15 of 17
mspatz
I'm so confused. Just plot the deed and make it close with a parcel segment line. Than put that segment on a no plot or layer to freeze so it doesn't show. You get what you want, a parcel is created because it is technically closed but you don't see the closing segment.
This is what we do and it works great...
mspatz
[p.s. don't get me the area argument. If you have an issue with the area don't show the parcel calculated area or create your closing segment in such a manner that you get the desired area. Besides, typically in this case you wouldn't show the parcel area you would simply input the deed area since you are not doing a determination].
Message 16 of 17
OR:
Use the line and label it "Linear Error of
Mis-Closure".
<G>
Bill
I'm
you don't see the closing segment. This is what we do and it works great...
mspatz [p.s. don't get me the area argument. If you have an issue with the
Message 17 of 17
hafiz.khan
in reply to: ralstogj
respected sir, i need a lisp which can calculate bearing distance and area i hope you will help me
Rail Community
