Civil 3D Forum
Link slope to surface projection
6 REPLIES 6
Joe-Bouza
1683 Views, 6 Replies
I'm sure this has been discussed and I just didn't pay attention at the time.
I am re-routing a small stream. I am using generic links for the bed and side slope. I whant the side slope to be 3:1 and project beyond the existing culvert wall in the eg model. can this be done easily?
Your Name
Your Name
6 REPLIES 6
fcernst
in reply to: Joe-Bouza
Use DaylightMultiIntercept with InterceptNumber set to 2.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Joe-Bouza
in reply to: fcernst
Mega Kudos Fred.
I could have looked for a month of Sundays and never found that gem
Your Name
Your Name
bf
I have a LinkSlopeToSurface subassembly part and I don't see an Surface Target choice anywhere.  The Subassembly help says there is one. Do y'all know where this is?
Joe-Bouza
the surface is assigned in the corridor not the assembly.
Corridor properties >> set all targets
Your Name
Your Name
bf
Thanks for your reply.  I set that.  My situation is I have an assembly with two slopetosurface links.  I would like one to target on surface and the other a different surface.
Joe-Bouza
Ahh.
My issue was one surface with multiple intercepts in your case there is another daylight sub called daylight multiple surface
Your Name
Your Name
Rail Community
