Civil 3D Forum
Link Code Hidden in Corridor Section View
10 REPLIES 10
Message 1 of 11
onsionsi1
1273 Views, 10 Replies
I have a problem with editing in link code because it didn't appear in corridor section view as you can in attached files.
And i think the problem appeared because there were some additional subassmbly (not original Subassembly) beside the original Subassembly and i also checked my sample lines and it didn't intersect alignment twice as if you think it intersected alignment.
Any advice will be appreciate
Thank you.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
10 REPLIES 10
Message 2 of 11
onsionsi1
in reply to: onsionsi1
Any advice Please
Message 3 of 11
tcorey
Post your drawing...
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 4 of 11
Try checking your Front Clip and Back Clip distances in the section editor, in View/Edit Options.
 Mine are set to 0.1 and -0.1.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 5 of 11
Thank you Mr.Andrew for your effort.
As you can see in attached file iset all thing as your setting but nothing happen.
I think my issue here as you can in attached file there are additional subassemblies(fake) beside my original one and let me tell other station had a link code and everything was ok because there weren't any additional subassemblies.
May if you haven't any idea i will post my DWG.
Thank you.
Message 6 of 11
onsionsi1
I figure out an issue and let me explain what happened.
Additional subassemblies(fake) appeared at hairpin location only
As you can see in attached file i have a hairpin in my project
For your Advice
Thank you
Message 7 of 11
In the section editor, you can use the "Viewport Configuration" command on the "View Tools" tab to set the view to show the plan and section (and the profile) which might have shown this a a bit earlier.
Andrew Puller
Civil 3d 2021
Message 8 of 11
onsionsi1
in reply to: tcorey
Dear Mr.Tim,
Can you give your email because i can't upload more than 1.5Mb here in this forum
Thank you.
Message 9 of 11
onsionsi1
Dear Sir,
You can download my file that describe my issue from the following link:
Your files are ready to be downloaded by your recipients
Download expiry date:Friday, January 04, 2013 12:17 PM
Download limit:10 times
Password:-
Link to download page:
https://www.filemail.com/dl.aspx?id=SZQQQEHTHZQGNAO
Message 10 of 11
BrianHailey
The drawing you shared the links show up just fine on my system. You can see it HERE.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 11 of 11
onsionsi1
in reply to: BrianHailey
Thank you Mr.Brian for your reply,
When i looked to your system i found that you have 2013 version after that i open my DWG with that version and i finally got my issue that 2012 version had some bugs.
What i'm lookin for what about the earth work quantity if you looking to overall corridor section editor you will see some additional bugs in link code as you can see in attached file
For your advice.
Thank you.
Rail Community
