Civil 3D Forum
Linework Field to office
1 REPLY 1
strimenos
253 Views, 1 Reply
I am trying to find the right coding pattern to connect the BL1 line on the extension of the OFF1
The feature i try to survey by using GPS can not be reached... So i try to survey it by using extension. Survey two points on a straight line and then using the X code to extent the line. the problem that occurs is that the BL1 is not connected on the extension but on the actual survey point.
I am using leica viva which has the double distance option but is not that practical or applicable
I attached an image showing the problem
Any ideas
Thanks in advance
1 REPLY 1
IanMcClain
in reply to: strimenos
The problem here is that you can't have the linework codes piggyback on one another: each time you call a linework prefix it ignores any others and uses the actual point location as reference, not the extension of the previous linework prefix.
You needed to use the offset features in you data collection software to get stored point 7 to be where you want the lines to intersect. If elevation is not a concern I would have used the data collector to generated a point 8 that is on line 7-6, 20' from 7 with a code "off1 bl1" and left point 7 as off1. Offsetting a point 20 feet is not good survey practice in general, but I don't think you can make the codes do what you are asking.
Ian McClain
Rail Community
