HAVING TROUBLE GENERATING THE THE AUTO LINEWORK PROPERLY, I HAVE A FIGURE PREFIX DATABASE CREATED WITH ALL THE STYLES ETC.. AND HAVE OUR LINEWORK CODE SET SETUP. IT WILL NOT DRAW THE CURVE SEGMENTS OR CLOSE ON FIGURES. THE CODES WE ARE USING IN THE FIELD ARE THESE.
BC B (BACK OF CURB BEGIN)
BC BC ( BACK OF CURB BEGIN CURVE)
BC POC ( BACK OF CURB POINT ON CURVE)
BC EC ( END OF CURVE)
IT WILL DRAW THE LINES FROM POINT TO POINT BUT IT DOES NOT CREATE THE CURVE SEGMENTS.
If your importing via ascii file that looks fine, but I don't believe it works via fbk, someone correct me if im wrong
Also, drop the POC (not needed) that is the possible culprit
Rick Jackson
Survey CAD Technician VI
