Using 2013 C3D. My text and linework is now gray. During opening/initializing of drawing, everything appear fine until it finishes loading, then everything is gray. It just started yesterday when I was bringing in shp files of wetlands in various ways (dragging/dropping, fdo conect and mapimport). Maybe the shp file had nothing to do with it, but I've never seen cad do this.
When I grip the line, the color in layer comes up as correct color, but the line on screen is gray. Also if I copy the multileader or line, the color reverts back to correct color until I save, exit and reopen. BTW - the only thing that isn't gray is my civil 3d pipes and structures.
Any ideas on why everything is turning gray??
Solved by sfore. Go to Solution.
Rick Jackson
Survey CAD Technician VI
I've typed AUDIT about 39 times.
I just figured it out.....If 'Default' is toggled under Map Base inside the Task Pane of Mapwspace, then features will appear gray, toggle it off and back to normal.
