Civil 3D Forum
linework and text turning gray
6 REPLIES 6
sfore
2417 Views, 6 Replies
Using 2013 C3D.  My text and linework is now gray.  During opening/initializing of drawing, everything appear fine until it finishes loading, then everything is gray.  It just started yesterday when I was bringing in shp files of wetlands in various ways (dragging/dropping, fdo conect and mapimport).  Maybe the shp file had nothing to do with it, but I've never seen cad do this.
When I grip the line, the color in layer comes up as correct color, but the line on screen is gray.  Also if I copy the multileader or line, the color reverts back to correct color until I save, exit and reopen.  BTW - the only thing that isn't gray is my civil 3d pipes and structures.
Any ideas on why everything is turning gray??
6 REPLIES 6
Jay_B
in reply to: sfore
Are the Layers locked?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
sfore
in reply to: Jay_B
no, nothing is locked
rl_jackson
in reply to: sfore
Audit Audit Audit
Rick Jackson
Survey CAD Technician VI
sfore
in reply to: rl_jackson
I've typed AUDIT about 39 times.
I just figured it out.....If 'Default' is toggled under Map Base inside the Task Pane of Mapwspace, then features will appear gray, toggle it off and back to normal.
fautodesk
in reply to: sfore
Check your visual style.
lorrie.bundy
in reply to: sfore
Changing "default" in mapwspace worked for me also...Thanks!!!
Rail Community
