Civil 3D Forum
Lineweight display after save layout to drawing
1 REPLY 1
petrocat
650 Views, 1 Reply
In Civil3D 2012, I have created a subdivision plat using Parcels, Parcel tables, surfaces, xrefs, and a using a layout for the finish product. I then wanted to kick the tires a little, and use the "Save Layout as a Drawing" command, to make a new .dwg with what is seen in the paperspace. This is in theory a handy tool, as some clients we've had want a CAD file of each sheet (I'm sure they have their reasons).
After my first unsuccessful attempt, I figured out that I had to export the file to ACAD to get rid of the Civil3D object. That's fine, not too much of a workaround for one file, but when doing multiple files I think it might get ridiculous. After that I successfully used the "Save Layout as a Drawing" command to make a new file.
Now the problem: the lineweight display is wonky. All the lineweights are displaying outragedouly thick, even when the settings are correct in unit and exaggeration and the "Display Lineweight"  is unchecked. I can check it on and then check it off, and the lineweights will display normally until I pan, zoom, regen, regenall. I've purged, audited, closed, shutdown, restarted, rebooted computer, tried it from another machine, and still the lineweights are wonky.
Any suggestions?
Mark
Win 7 x64
Civil 3D 2012
1 REPLY 1
david.zavislan
in reply to: petrocat
The export layout command converts everything to model space.  Model space does not have a view scale like paperspace viewports.  Since there is no scale, the lineweight display is based on the drawing window zoom factor - as you zoom in the lines get thinner and as you zoom out they get fatter.  This should only be a display issue.  When plotting, the lineweights will be based on the selected plot scale.
David Zavislan, P.E. | Wood Rodgers, Inc.
Rail Community
