AutoCAD Civil 3D General Discussion
tworzella
Message 1 of 10 (1,818 Views)
Accepted Solution
Linetypes bad definitions in autocad 2014 work fine in civil 3d 2014
1818 Views, 9 Replies
07-18-2013 04:08 PM
Load linetype file in autocad 2014 and I get bad definitions on a couple. Load they exact same file in civil 3d 2014 and all linetypes load fine and work correctly. It looks like all the support files are pointing to the same folders for both.
Does Plain Autocad read linetypes and shapes different that Civil3d?
Todd
You're certain the support folder are the same?  it sounds very much like AutoCAD is not finding a custom SHX file.  In C3D, type (findfile "MyFile.shx") replace MyFile with an SHX file you know is referenced in the LIN file.  Then do the same thing in AutoCAD.  This piece of code will tell you if/where the file has been found.  They should be in the same place.
Also, make sure AutoCAD ius loading the exact same LIN file.  Use TYPE and load the file manually.
I added this path to the support path files in AutoCAD. Then the complex lines worked. Plain AutoCAD does not have something in its support file that Civil3d has but not sure what. In any case it's working now, but may need to figure out what to send along to my plain AutoCAD users in other firms to get it to work.
C:\Users\toddw\AppData\Roaming\Autodesk\C3D 2014\enu\Support
Thank You,
Todd Worzella
*Expert Elite*
mathewk
Message 2 of 10 (1,800 Views)
Re: Linetypes bad definitions in autocad 2014 work fine in civil 3d 2014
07-18-2013 06:15 PM in reply to: tworzella
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
*Expert Elite*
rkmcswain
Message 3 of 10 (1,771 Views)
07-19-2013 04:08 AM in reply to: tworzella
As
tworzella
Message 4 of 10 (1,749 Views)
Re: Linetypes bad definitions in AutoCAD 2014 work fine in civil 3d 2014
07-19-2013 07:52 AM in reply to: tworzella
Finding shx files in same file locations in both civil and AutoCAD. The linetypes having issues are using shapes. The one I'm working with is a silt fence that has boxes along the line. This line was created by modifying some of the old complex linetype deigns from Land Development Desktop.
Issue appears with all these complex linetypes, but only in Autocad. Work fine in civil3d.
*SILT FENCE 1-2, SILT FENCE (1/2)
A,.5,[BOX,AECCLAND,x=-.05,y=.05,s=.05],.5
Thank You,
Todd Worzella
Todd Worzella
Senior CAD Technician\IT Support
REI Engineering, Inc.
1991-2011...Celebrating 20 Years of Business Excellence!
4080 N. 20th Ave.
Wausau, WI 54401
Phone: 715.675.9784
Fax. 715.675.4060
Mobile: 715.551.1364
Email: tworzella@REIengineering.com
Web: www.REIengineering.com
[cid:image002.png@01CE8465.88120A10]
[image003]
[cid:image006.jpg@01CE8465.88120A10]
Providing practical solutions and exceeding client expectations in
civil engineering, land surveying, environmental and safety consulting.
IMPORTANT NOTE:
Confidentiality Notice: This message and any attached documents may contain confidential information. The information is intended
solely for the use of the individual or entity named above. If you have received this communication in error, please notify the sender
immediately by e-mail or telephone, at (715) 675-9784 and delete this message. Thank you.
*Expert Elite*
rkmcswain
Message 5 of 10 (1,744 Views)
07-19-2013 08:20 AM in reply to: tworzella
So in AutoCAD, type in SHAPE, then ?, then <enter>
Does it list the shape "BOX" under the file AECCLAND.SHX?
(It should list the loaded shape files and the available shapes in them, example below.)
Available shapes:
File: ltypeshp.shx
  TRACK1            ZIG
  BOX               CIRC1
  BAT               AMZIGZAG
*Expert Elite*
jmayo
Message 6 of 10 (1,743 Views)
07-19-2013 08:21 AM in reply to: tworzella
I don't know how that def is working without a pen down assignment just before the shape. Here's an example that works with a shape.
*STORM,Storm Sewer
A,0,-.1,[EQUAL,EQUAL,s=.1],-.1
From Help
Simple Custom Linetypes
Bottom of the Page
Each linetype is defined            on two lines in a linetype definition file. The first line contains            the linetype name and an optional description. The second line is the            code that defines the actual linetype pattern.
The second line must begin with the letter            A (alignment), followed by a list of pattern descriptors that define            pen-up lengths (spaces), pen-down lengths (dashes), and dots. You            can include comments in an LIN file by beginning the line with a            semicolon (:smileywink:.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
tworzella
Message 7 of 10 (1,740 Views)
07-19-2013 08:35 AM in reply to: jmayo
Works fine in Civil3d. We just started using 2014. We have the design suite and I was using plain AutoCAD for some drawings. And none of the complex linetypes from the old Land Desktop work in the plain AutoCAD. Guess will have to use the civil3d as AutoCAD to get them to work. Just wonder how these have been showing up when we send to outside firms without Civil3d. We always send the linetype files along for them to use.
I also saw something on the web that says that Autodesk is aware of an issue with complex linetypes and is working on it. Not sure if that is part of this issue or not.
Thank You,
Todd Worzella
*Expert Elite*
jmayo
Message 8 of 10 (1,733 Views)
07-19-2013 09:08 AM in reply to: tworzella
I use those LDD shapes to and they all work in 2014. Your def also worked without issue. I would confirm as stated above that the shx file is in one of the support paths. Also confirm the file size in both installation paths is the same.
John Mayo, PE
IDSP 2014
tworzella
Message 9 of 10 (1,729 Views)
07-19-2013 09:21 AM in reply to: jmayo
Thank You,
Todd Worzella
*Expert Elite*
mathewk
Message 10 of 10 (1,724 Views)
07-19-2013 09:25 AM in reply to: tworzella
It's the SHX file that AutoCAD does not have. That's why the path to this SHX file need to be in the support files paths.
Please note we have moved. Our new address is:
4040 Graveley Street
Burnaby, BC
V5C 3T6
Matt Kolberg, Applications Specialist
c: 604.803-5963
Improving field to finish productivity
cansel.ca [Description: Description: Description: http://www.googleplus-vs-facebook.com/facebook.png] <> [Description: Description: Description: http://t0.gstatic.com/images?q=tbn:ANd9GcQkxJl0nu584FrSblIknohzw0tAMtmGSSs9hAnxRS6kFOpzPYmvXQ] <>
[autodesk customer satisfaction program new]<>
Matt Kolberg
Need installation help?
