we use a custom treeline for all our drawings and as of late we can not publish this line type. The tree line will plot fine if you plot the individual pages but when you try to publish and plot all the pages as a group, it plots the tree line as a dotted line. Any help would be great. I checked the plot styles and it's set to use object linetype. Like I said though it only seems to have this problem when publishing the drawing
thanks
What if you publish using Sheet Manager? Do you get different results?
Does this linetype cause issues in all drawings or only certain drawings?
Can you publish to a different device or file type (PDF or DWF) and get different results?
Tim
So far this has been an issue in all my drawings and I have tried plotting to PDF and other plotters, it all comes out the same way. Im not sure what you mean when you refer to sheet manager. I am having this issue when I use the Publish comand, which will bring up all my sheets in what appears to me to be a sheet manager but not sure what you are refering to
thanks
Sheet Set Manager is an interface that helps you organize and manage your project sheets. Publishing from Sheet Set Manager sometimes produces better results than publishing with the Publish command.
If you publish more than a few sheets in a set, you might want to read up on it or look it up on YouTube. Here's a good overview of Sheet Set Manager if you have an hour: http://www.youtube.com/watch?v=s7YeFjeN66g.
Good luck in your studies!
Tim
Does it make any difference it you have this drawing OPEN during the publish vs. having it CLOSED during the publish?
Sounds like a shape file that can't be found.
As a test.....can you change the linetype to a non-complex one (like hidden or dashed) and see if it publishes OK?
Im working on the sheet set idea now thanks for the input. i have never tried publishing while the drawing was closed and anytime i open a drawing it prompts me to locate the shape file so im not sure if that is the issue or not\
thanks
Ok so sheet set manager did not solve the issue, the line type is still coming in as a doted line instead of the tree line
@Anonymous wrote:
....... and anytime i open a drawing it prompts me to locate the shape file so im not sure if that is the issue or not\
thanks
That sounds like it. Put the required shape file in your support file search path -or- add its current location to your support file search path.
Publish again.
Temporarily disable background publishing. This will allow you to see any errors that are occurring during the publish command. You can toggle background publishing in the OPTIONS command.
