Civil 3D Forum
linetype scales
3 REPLIES 3
willpyle7693
6639 Views, 3 Replies
linetype scales
my linetype scales in model space look good, when i go to paper space to print the linetypes are huge and way out of wack. what is my problem?
3 REPLIES 3
Set the linetype scale (LTSCALE) to your drawing scale and in Paper Space set PSLTSCALE to 0.  Make sure you do a RegenAll (REA).
Todd Rogers
Jeff_M
in reply to: ToddRogers-WPM
IMHO, a better way is to set PSLTSCALE, LTSCALE, and MSLTSCALE all to 1. Then the scale of the viewport dictates what the linetype looks like...differing scaled VP's will all have the correct linetype displayed.
coopdetat
in reply to: Jeff_M
Thanks for the help.  I could not figure out why my linetypes in model space were huge... its the first time I ever heard of MSLtscale!  I set it to 0 and they look like I expect them to again.
My typical method is to keep everything except annotation and any static info in separate xreferenced files.  (Static info = info that never changes appearance regardless of the sheet layout)  In my scenario there are no paperspace viewports to consider when I am editing the model so I give the model a fixed ltscale and dimscale.  After I moved to C3D 2013 I have been baffled by the unexpected linetype scales.  I haven't worried about it much since they are correct on the sheets which I set up the same as you (except for the unknown MSLtscale).
Thanks to your post I now know about MSLtscale.  I used to enjoy perusing the readme file where the new commands, system variables, etc. were listed.  It is much harder to find this info now (for me anyway).  I give up too soon I guess.
---------------------------------------------Signature--------------------------------------------
Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
Windows 10 Pro 64-bit Intel﴾R﴿ Core﴾TM﴿ i9-12900KF CPU 3.19GHz; 32 GB DDR4 4266 Dual Channel RAM
nVidia Quadro RTX 4000; AutoCAD Civil 3D 2023.2.1 Update
Rail Community
