akbarg
Message 1 of 10 (242 Views)
Linetype problem
242 Views, 9 Replies
12-02-2012 01:06 AM
I got these two files from a client along with indentical custom line types. The strange thing is that the lines show allright in one of them (OK), but not in another (NOTOK)! I tried every possible System Variable but nothing works! Can anyone find the problem?
I tried:
Measurement
Measureinit
Ltscale
Celtscale
Units
Fillmode
Distinguished Contributor
SurveyorLee
Message 2 of 10 (217 Views)
Re: Linetype problem
12-02-2012 07:21 PM in reply to: akbarg
no one else has responded, so I will take a stab.  I have not looked at your files, but be sure you have the
msltscale set the same for both and the psltscale
then you will need to look at the actual linetype file to see what is different.  Something has to be.
Surveyor Lee
akbarg
Message 3 of 10 (205 Views)
12-03-2012 12:01 AM in reply to: SurveyorLee
Thanks!
I've been using AutoCAD for about 8 years and still learning about all of these System Variables!
I'm sure I cleared all variables that connect to the line type even msltscale.
This problem should be related to something other than line type, but it indirectly affects how things show on screen!
I await more responses!
Have a good day!
Neilw
Message 4 of 10 (188 Views)
12-03-2012 06:50 AM in reply to: akbarg
Are you receiving any error messages regarding missing .shx files when opening the drawings?
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
rkmcswain
Message 5 of 10 (181 Views)
12-03-2012 07:16 AM in reply to: Neilw
OP: Be aware that it's possible that these warnings/errors are being suppressed.
Options>System>Hidden Message Settings
Neilw
Message 6 of 10 (172 Views)
12-03-2012 08:12 AM in reply to: akbarg
Here is what I suspect has happened. When I open the NOTOK.dwg in Microstation, I receive warnings about missing Architectural Desktop 2007 and Civil 3D object enablers. This tells me the drawing has been modified by an Autocad application after it was converted from Microstation. If so then likely the linetypes got changed when the drawing was modified.
When I compare OK with NOTOK, the lintypes between the 2 drawing are not identical. There seems to be a scaling problem with the linetypes in NOTOK. I think you'll need to investigate the history of the NOTOK file.
I should qualify this by noting that I had to use DWGTRUE convert to convert the files to ACAD 2007 format so I could open them in my version of Microstation. I don't know if that process caused the object enabler warnings, but I doubt it.
WIN 7 64 PRO
RADEON 6450, 1 GB
Neilw
Message 7 of 10 (166 Views)
12-03-2012 08:37 AM in reply to: Neilw
Hold the phone,
I just noticed that when I open OK I get the missing OE warnings also (Microstation doesn't present a waring dialogue so I missed seeing it in the message center). Still there are some additional messages in NOTOK that make me suspect something has happened to make it differ from OK.
WIN 7 64 PRO
RADEON 6450, 1 GB
Joe-Bouza
Message 8 of 10 (142 Views)
12-03-2012 05:36 PM in reply to: Neilw
When I open the drawings I get a "Drawing file not created by authorized Autodesk product... bla bla bla.
I cant help but think this has something to do with the problem
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Neilw
Message 9 of 10 (136 Views)
12-03-2012 06:59 PM in reply to: Joe-Bouza
Joe,
Noting the names of the .shx files included in the dataset I'm sure the files were created in and/or exported from Microstation. That still does not account for the difference between the 2 files.
WIN 7 64 PRO
RADEON 6450, 1 GB
Joe-Bouza
Message 10 of 10 (120 Views)
12-04-2012 04:39 AM in reply to: Neilw
Yeah, but is it possible the shx files are faulty due to their creation?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
